radio harness diagram?
83Cutlass2181
119
does anyone have a diagram of which color wires are what, on the stock harness? thanks.
pokertramp
564
If you have the factory radio it says it on there I think, it did in my 1982 Regal.
Doober
1,253
20
38
Swartz Creek, MI/Tucson, AZ
Most all the GM vehicles had the same colors for 4-speaker wiring, I'm pretty sure the power/ground/illumination wires are the same as well. If you're adding an aftermarket stereo you'll probably have to pigtail off a constant +12v... many have used the orange wire running to the cigarette lighter, and I believe that's what the radio memory is tied into on newer cars as well.
I just found this, could prove extremely useful.
http://www.installdr.com/Harnesses/GM-Wiring.pdf
J3
134
2
16
East TX
Doober
1,253
20
38
Most all GM vehicles have used one of only a few different connectors for the radio. Those that had add-on amplifiers sometimes had additional connections, but they were separate from the regular radio harness.
