Radio HELP ! 81 cutlass Calais
DUBWBC
14
9
Detroit, Michigan
So I bought my first Gbody last year and as we all know it's a process I recently changed my ignition switch out now I can't get my radio to come on but before I changed it the radio was working does anybody kno which wire would effect that on ign switch or what fuse or wire would cause it not to turn on
67rstbkt
556
10
Reno, Nevada
The radio fuse(s) will be under the driver side dash. They should be labeled; you can narrow down the issue with a test light or multi meter. If you are unsure of which fuse to check, just turn the key on and touch a test light to both ends of every fuse - if you find any with power on one side of the fuse only, it's blown.
The power wires at the radio end should be:
Constant 12v = Orange
Ignition/switched 12v = yellow
Ground = black
