Radio wiring help
Montecarlo79
10
11
16
Orange 12v constant missing to radio, can I just take accessory power from fuse panel cut the grey wire and splice in new one going straight to accessory power
The grey wire in your photo is for the radio illumination. Pictures below show which wire went where on a factory 79 install.
12 volt + (Key on) is Yellow
Ground - Black
Lamp Gray
If you are looking for a 12 volt + constant on (For memory on an aftermarket system you will have to run a wire to the fuse block and attach at a BATT (12 Volt non switched) opening in the block.
Reactions: Sweet_Johnny
Ground - Black
Lamp Gray
View attachment 254876View attachment 254875
Thank you for the clarification I thought that would be the case, adding on I’m trying to wire up my triple gauge pod lights/ volt gauge and there’s 4 spots on the fuse panel that I could plug into and when I turned the key it worked for a second and I went back to that with a tester light and no power with key on, did I break something?
Thank you for the clarification I thought that would be the case, adding on I’m trying to wire up my triple gauge pod lights/ volt gauge and there’s 4 spots on the fuse panel that I could plug into and when I turned the key it worked for a second and I went back to that with a tester light and no power with key on, did I break something? In the photo I circled where I got my key power
Start checking fuses. 20 amp gauges and the 15 amp radio. If they are good there is a chance you went to ground and burned the fusible link at the starter. If you have no power to the dash or are unable to start the car it is a good chance one or both fusible links are blown.
I’m able to start the car
Found the issue thanks, why are my fuses burning up every time I put my gauge wiring in though?
Was just going to suggest checking fuses. You beat me to it.
Retrace the wires in your gauge set up. you may have a power lead wired to ground or a wire connector that is grounded at the attachment point. Possibility of a bad gauge also, I have seen new offshore gauges that were defective.
This is how I have it set up, the wire I’m holding in the picture it what I’m plugging into my fuse panel
