I had problems with mine this past summer.
Symptoms:
1. Battery not charging because the voltmeter was not connecting
2. No idea how much gas I had left
3. no illumination of gauges
I figured out it was not the gauges themselves, or any wiring on the harness. Also, the printed circuit board was in near prefect condition.
The problem was where the printed board presses into the dash. No matter what I did I could not get the little prongs aligned right and all even so the flat printed board would mate correctly. Eventually I took the whole gauge pod inside and used a soldering iron and some solder and made little "nubs" on the end of each circuit path where they rest on the prongs in the dash. I just heated up the solder enough to "drip" a little bit onto the tip of copper flaps. I made sure each drop was about the same size and all lined up. I installed the pod back into the dash and everything worked perfectly and no more short circuits.
