Thinking aboot switching the granny speedo out for a rally dash in the 78 Cutlass.
A few questions for the more knowledgeable folks regarding a few details.
1. "any cluster will work" seems to be the standard answer, however the 78 is a column shift car.
A lot of the dashes I see have the block off plate for the shift indicator. Can the indicator be swapped from a granny speedo to a rally dash?
2. Aside from adding the sending units for oil, and temp, is there a speedo drive cable difference from early to say later 82+ units?
3. To run the rally tachometer, I'd need to add the tach wire with resistor also?
Thanks in advance.
Thanks in advance.
