3XBrownCutty said:so where can i attatch the ground? just anywhere on the tach circuit board, or anywhere on that plastic board on the back? does it matter?
I read a guy cut away the plastic over the copper and drill a hole and sandwitch a piece of wire on the copper with a nut and bolt.
any ideas on the oil pressure?
OH RLY!!!! Was it on Oldspower.com. Becuz thats exactly what I did. Im Rok_Stars_Bars on Oldspower.com.
But Yeah, I found what circuit on the PC board is the ground (The whole PC board uses the same ground.) So you know one side of the lamps are ground. I drilled a hole kinda next to the right blinker, but more behind the speedo. And like you said just sanwdwich the terminal. Thats fixed my blinkers not working, high beam lights, and Illumination lights. And like I said I had to take the 5 nuts off and get a steel brush and clean the exposed copper for the guage. Then my guages started working.
Oh another problem I had. Was the rallye pac was not tighting down all the down. My bottom outside screw was the wrong side. And it wasnt tighting up all the way and the connector 2 wasnt mating correctly with the PC board. My temp guage was working then.
And last one I think. I bent all my prongs up on the connector 2 (I think thats the one, anywayz the one you have to rewire). And I had one of the prong get hung up on the plastic connector and wasnt moving when I installed the guages. And wasnt allowing the rest of the prongs to have contact. Nothing worked then.
My thread on Oldspower.com
http://www.oldspower.com/vb/showthread.php?t=53459
