I have an 86 Olds Cutlass, with a 403, the car has from as far as I know factory Rally gauges,however at a confirmed 800rpm the tach reads 11-1200 RPM, at 180-190 Degrees my water gauge reads 220 Volts are always 12.5-13, I know my charging system is in good condition, my battery is strong, and when I installed the 403 I put in a braided ground strap from the head to the firewall, and a 4 gauge from the block to the frame. Whats wrong here? I used Standard motor parts sensor TX 3 for the Computer and TS76T for the gauge. Are they the right sending units?
