FE3X CLONE said:Do you have a center console? Looks like the plug to the center console wire harness.
565bbchevy said:Is there any power accessory besides your trunk release that is not working?
I would check and see if it has power from battery or ignition so you know whether or not it feeds something or is supposed to get power.
If everything on your car works then it might just be for an option you that don't have.
565bbchevy said:Well I wouldn't worry about it then, it's probably just for an option you don't have, just fix your trunk release and be done.
565bbchevy said:I think on mine it runs down the passenger side and my switch was in the glove box but just follow the harness from the the decklid and you will see which side it is on.
