Rattling in front end of 85 Cutty
Flowers85Cutty
42
4
8
44
I am going nuts trying to figure out what is rattling in the front end. I thought I had it figured out and finally got around to replacing sway bar end links and bushings. Once I dropped the car to test drive, ride felt better but still had the rattle! It sounds like a heavy chain rattle.
Any thoughts would be helpful.
I will check out the caliper bolts. It would make sense that it stops when the get loaded. Although the that thinking cost me some time on sway bar! It was needed anyways.
Thanks
check the pads too to see it they are moving around. The inner pad has the retainer clip that could be broken and on the outer pad I bend the tabs to make sure they are a snug fit and use the disk brake quiet
