Re: Check Out My $200 Cutlass
Considering how bad these cars can be with the roof rot issue, I would consider having the roof changed by a body shop. Just be sure to get a roof from the good factory that painted all their pieces before welding and not after. The before welded ones don't really rot out. Besides, if it is that bad, the understructure is probably rotten too. Other than that, it is not a bad starting point. It seems that the interior plastic is in good condition and that all the trim is there. Those items are half the battle. Seeing as you are in Florida, I would try to find a new pair of doors with no rot in them. I doubt you have a self serve yard in West Palm, but there are plenty in this state. 81-88 Cutlass and Regal doors are identical except for a few trim pieces. That makes them some of the easier doors to find. I tend to use LKQ a lot as they are all over the state. I would also undo the ghetto A/C deletion and at least get a proper non-A/C heater box in it. You also have a trunk seam leak by the back window. When I did mine, I elected to acid etch the rust away and then seal it good with JB Weld epoxy. Time will tell if it was a good idea, but no problems have come up after over a year.
