Thats what I was thinking but I wasent sure how sturdy the bracket would need to be. Also if placement is that important. On the stock rear the block attatches pretty low, basically at axle level. With my center a simple L bracket wouldnt work so well in that spot. It would probably work ok on one of the top couple studs on the center though. Do you have any pics of where you mounted yours?A simple L bracket off one of the center section studs works pretty well.
I just welded a bolt to the housing since the hose end has a mounting hole in it.
Hahaha! Awesome! I just saw the first picture and was like, WTF? He's just f'n with us making stuff out of index cards. Hilarious.That's how I did mine. Made a pattern out of an index card, then repeated it in metal.
