i notice a flat part on the shock mount about 1 1/2" inboard and around 45 degree angle from origional shock hole. i drille the new hole a 1/4" lover than the stock mount hole, the hard part was getting the shock mounting hole to go at a downward angle to align the upper and lower mounts so as to eliminate bind. i did weld a bead around the top of the holes to make the bolt angle downward, and a lot of die grinder work. i noticed that even the stock mounts had some binding. used a 3 1/2" 1/2"X13 bolt, used a allen head bolt because they had more threads than a hex, to use a hex i would of had to cut more threads, i went the easy way. for a bushing in the shock i used a bush i had cut to 1 3/8" long, it was .700" dia, .625 would of been better, but i didn't have one, the .700" worked nicely with a little rubber lube, and don't for get a little grease on the bolt part that goes thru the shock. i used 1 1/2" washer on either side of the shock rubber, they tightened up snug to the rubber with 1 3/8" bushing but not overtight. i don't own a hoist (in the future), this would of been a easy job with a hoist, it is hard to work on the floor. this gave a lot of clearance for disc brakes in the future and brought the shock closer to vertical. the bolt arangement goes the head of the bolta lock washer to the head two big washers one on each side of shock one nut, two flat washers, put bolt thru mounting hole a lock washer and nut.
