Rear window trim interchange
realjwann
14
Took off landau top and now i need the rear window trim, i have been unable to find the trim off a cutlass, but there are numerous other g bodies around, including monte's and regals, does the rear window trim off of these g bodies swap into the cutlass?
Sep 1, 2006
6,687
34
Tampa Bay Area
It should fit no problem. Just be sure to get all of the trim clips that go on the bottom pieces because they use a unique clip that works with the filler panel.
fodoimp
370
2
Southern New Jersey
I found out from my similar problem that monte carlo ss does not have a bottom piece of trim it is only three pieces however buick regal is exactly the same. hope that helps
