You have to make sure you get pre 88 s10 carriers though. They switched to 28 spline axles, I believe 88 was the official change over year but i have run into some 87's as well. Also good to double check the spline count in older ones as well, just in case they were previously swapped.anakputa said:The S10 guts will work. if you know how to set up rearends..
