Regal Console Riser In Cutlass?
I cut the storage compartment off of the shifter/ash tray. There is also a "C"-shaped plastic extrusion under the compartment that sticks up above the console base that I had to cut off. Once that was done, it just slid over the top. It is a pretty tight fit. The seat backs rub a bit when you tip them forward.
thanks may give it a try
