Removed all CCC components now what's the next step?
TheBandit203
49
6
I will try to get everyone up to speed, 87 Regal w/ 350 trans I just change the carb non CPU controlled, edelbrock performer intake manifold, and headers as well as the distributor! So my question is, might there be a how-to or a wiring diagram I can follow to remove unneeded wires and there former harnesses? Thanks in advance
Kai
All the wiring comes up under the AC box, just roll up the unwanted wires and tuck them away. No need to cut them out like many people do.
Former "Bandit" project 86 Regal
New "Bandit" project 87 Regal w/astro roof
Both together checking the q-jets carbs
The madness
Love those slots! 8)
So what do I do about the harnesses afterwards? And anybody got info inca wiring diagram?
Not sure what you are looking for, you don't have to do anything else. The harness for the ECM is seperate from the other harnesses.
take the cpu out from the passenger kick panel and take the whole harness out, you'll have to remove the passenger side fender to get this done (at least i did) it takes some patience to do it on gbodies without scratching the door but tak your time and its worth cleaning up your engine bay
this is what you'll end up with... plus some! :mrgreen:
for reference: if you can see where the wiring harness comes out just below where the heaterbox sits, just below it will be a second harness- that'll be your CCC wiring. (mine was already out when this was taken)
nice regals btw... 8)
