Hello all,
i have a 1986 Grand Prix "Brougham" and i'm trying to remove the instrument panel "cover" from it.
the problem is that it's a single big piece of molded plastic and it gets stuck in the steering column. there's a bulge on it for the shifter that the panel gets stuck on
i've tried removing the steering wheel in the hope i'd be able to move the column forward a bit but no luck from that angle. i got down to the "click wheel" that's on top of the plastic flasher cams and i don't see any way to get any lower than that
any other tricks i should be aware of? im pretty much stuck here now
