rewirring my monte ss.
gbodydude
128
i want to rewire my car.the wirring is all hack up.has any one done this? can someone give me some advice on it?
jonnyslick
697
2
Crossville, TN
I've never done it ... but I've seen Painless Wiring kits done before and they are clean and complete. I guess the other option would be going to a wrecker and pulling a complete harness out of another and installing it. Problem is that you'll have to fix what's broken and you'll still be dealing with 20+ year old wiring.
You could custom make your own, but if your like me and have about zero brains when it comes to that stuff ... it's better to get completed harnesses done for you.
I'm going to use the Painless stuff when I re-wire my 1974 BMW. When I did the engine swaps in the 240's I would always pay a wiring service to do the work for me so that it was "plug and play" ...
cuz i aint gots no time to be fooln' with no stinkn' wire'z! :lol:
Sep 1, 2006
6,687
33
Tampa Bay Area
An easy option, if you can find it, would be to pull an un hacked harness from a junkyard donor car. I did this on my car when I added options, and swapped from a Buick 3.8 to a Chevy 350. The car has several subharnesses, so you probably don't need all the wiring in the car, just the appropriate subharness. If you need a dash harness, you will need to remove the dash to get it out, and unbolt the bulkhead connector at the firewall so that you can remove the dash side with the fuse panel attached. It is not hard to do, and will take around half an hour to dismantle once you know how.
gbodydude
128
rewirring my car
i have a big block and a turbo 400 in it,plus a delated the a/c,and added autometer gauges to it.
Sep 1, 2006
6,687
33
Tampa Bay Area
What do you need to rewire? Do you plan to keep the stock switches, etc? Which circuits? I am not going to sit here and type out a massive response to a vague original question.
gbodydude
128
rewirring my car.
sorry, i think i just need to rewire the engine and interior.i well be useing autometer gauges in it. also i'am pulling the a/c out.and i'am instilling a 400 sbc with a turbo 400 trany. thanks for you time and help
dougfather
286
5
16
Altoona PA
Check out my sticky in the Engines/Swaps forum. I have the engine harness wiring there. I have schematics for this stuff too.
gbodydude
128
thanks,
