Right front swaybar bushing?
81cutlass
4,730
13,949
Western MN
Bought an F41 GN front swaybar last weekend and was going to order bushings but the actual size of the bar has me confused. The bushings off Summit Racing are 1 3/16 but the bar is 32MM and that goes out to 1 1/4". Does 1/16 matter? Should I go poly bushings or is rubber fine? Its mostly a DD.
http://www.summitracing.com/parts/MOG-K5248/
the 1/16 will make a big difference, you might be able to pull it off with rubber, but it's gonna take some muscle to squeeze it together. there is a noticeable difference between the polys and the rubber bushings, for sway bars i always go poly. but you also want to get the correct length poly endlinks. same with rubber--the body bushings should match the endlinks.
i got the energy suspension polys at autozone or advance.
