unfortunately i was under the impression that the cam break in procedure (25min at 2k-2500rpms) was all i needed to do and the rings would seat. this does not appear to have happened as i kept fighting crank case gasses all of last summer. after break in i pretty much drove it like i stole it. i was fine except for high load/WOT conditions. then the dipstick or intake/valley seal would blow out. with warm weather coming around i want to try and seat the rings but am not sure of the right way to go about it. (of course i have to get the car running again first, i hate winter) i was thinking of taking the car on the highway for 20-30minutes, maybe stop for lunch then drive back. might this work? any and all suggestions are welcome and greatly appreciated.
i did do one thing wrong when i assembled the engine, i had some of that sticky red cam lube from compcams left over and put a light coat of it on the cylinder walls. i would have expected it to have burned off pretty quick, but what do you guys think? the engine did run rich at the beginning and gas got into the oil, but it has been fixed.
