RPO code help
3XBrownCutty
1,820
9
38
NW PA
www.cardomain.com
Decoded almost everything except for a few pesky RPO's I can''t seem to find anywhere: NY6, QVJ, 6BJ, 8ST, 9ST, and what looks like OLD??? Can't tell because paper is ripped.
Thanks guys, curiosity got the best of me, so I had to post this question :lol:
Dammit...and I had just put my RPO code book away...
NY6-Power Steering
QVJ-no listing (but Q's are wheel and tire combos)
The rest of them have no listing in my copy of "GM Production Options- Effective May, 1984". There are no O codes listed and no codes with numerical beginnings other than 1 listed in the book.
Are you reading this off the SPID label under the trunk, or a build sheet found in the car? If it is a build sheet, it may have different coding that was departmental in nature instead of the more generic RPO codes found on the SPID.
Thanks!!
I found the build sheet under the rear seat all chewed up by mice, all except for the RPO's thankfully. You're probably right about the other codes as I can't find them anywhere online or anything.
Actually, I didn't find a 7 on the sheet, But I'll double check, I probablly mised it. Thanks!
I also found it wierd that it says I should have a cushioned steering wheel, but I don't. Also I thought my interior color was dark briar brown, but it says it's "LT CAMEL"
Take the interior colors you find on that online list with a grain of salt.
It is a pretty generic list of RPO codes from several different model lines. A majority of them are correct, but if you find yourself questioning any of them, chances are, they're for another model.
Post up the others that you aren't sure about...
I've got a list I got from the GM manual, though it's for '85, not '83, but it'll be closer than what's online.
All the ones that don't seem right:
NK1 : CUSHIONED STEERING WHEEL
11A : STRIPE COLOR, ACCENT, TWO TONE, LT ROYAL BLUE/GARNET
67D : TRIM COMBINATION, CLOTH, LT CAMEL (D) (91)
67I : INTERIOR TRIM, LT CAMEL (91)
67L : SECONDARY COLOR, EXTERIOR, LT CAMEL MET (91)
67Q : MOLDING COLOR, LT CAMEL MET (91)
67T : TOP COLOR, LT CAMEL MET (91)
679 : SEAT BELT, COLOR, LT CAMEL (91)
I think all the 6's should just be the dark briar... I don't even know about the stripe
By the way Blake I just beadblasted the headers I got from you, turned out great, and I'll either spray them myself or get them powdercoated by my uncle very soon.
Well, with the differences between years, there was only one I was able to figure out from my list that you didn't have...
11A : Accent stripe, white
I don't know if this will help at all for any others, but here's mine that I broke down... I changed two of them to accomodate some modifications I've made... The blank ones I don't know.
ARL- PLANT CODE-ARLINGTON, TEXAS
AR9- SPORT BUCKET RECLINING SEAT
A01- WINDOWS, SOFT-RAY TINTED
BD2- EXT ORNAMENT-REAR END-DELETE
BS1- INSULATION ACOUSTICAL PKG OPTION
B34- MATS, AUX FRT/CARPET INSERTS
B35- MATS, AUX REAR/CARPET INSERTS
B84- MOLDINGS, BODY SIDE
B85- MOLDINGS, BELT REVEAL
B99- MOLDINGS, WHEEL OPENING DELETE (WJ4-W42)
CC1- ROOF PANEL TEMPERED GLASS-REMOVABLE
CD4- WIPER SYSTEM, PULSE
C41- LESS AIR CONDITIONING-BASE HEATER* should be C60 for A/C
C49- WINDOW DEFOGGER, ELECTRIC REAR
C87- LAMPS RR QUARTER COURTESY
D34- VISOR VANITY MIRROR
D35- MIRRORS, COLOR COORDINATED
D55- SPORT CONSOLE WITH SHIFTER
D7L- SPEEDO GEAR-30 TEETH
D85- SPECIAL ACCENT STRIPE (WJ4-W42)
E5Z- LESS SPEEDO GEAR ADAPTER
E7Z- LESS SPEEDO SLEEVE
F41- FIRM RIDE & HANDLING PACKAGE
GMD-
GT4- REAR AXLE - 3.73 RATIO
G87- RING GEAR-AXLE (8.50)
JM5- BRAKE BOOSTER - DUAL
K64- DELCOTRON-78 AMP
LG8- ENGINE, 5.0 LITER V8 4-BBL H.O. (VIN 9)
MW9- TRANS-AUTO OVERDRIVE THM 200-4R
MXO- TRANSMISSION, AUTO/OVERDRIVE
NA5- EMISSION SYSTEM-FEDERAL
NP5- STEERING WHEEL-LEATHER WRAPPED
N10- EXHAUST SYSTEM-DUAL (W48/W42)
N33- STEERING WHEEL, TILT-AWAY
N83- WHEELS-15X7 CHROME STYLED
QYH- TIRES, P215/65R15/N TL HWY-W42 OWL
TR9- LAMP & CONVENIENCE GROUP
TT5- HALOGEN HEADLAMPS-HI BEAM
T45- HOOD ASSEMBLY, ALUMINUM*
T83- HEADLAMPS-DOOR SPECIAL (W47/W45)
T88- AMBER PARKING LAMPS (W48)
UL1- RADIO DELCO-GM, ETR AM/FM STEREO
UQ1- INSTALLATION PROVISIONS -ETR
UT1- TONE GENERATOR-WARNING (TR9)
U21- INSTRUMENT PANEL CLUSTER RALLYE
U25- LUGGAGE COMPARTMENT LAMP (TR9)
U26- UNDERHOOD LAMP (TR9)
U27- GLOVE BOX LAMP (TR9)
U29- COURTESY LAMP (TR9)
U64- SPEAKER SYSTEM-DUAL REAR
U75- ANTENNA, POWER FRONT FENDER
VD6- FRONT BUMPER-REINFORCEMENT-ALUMINUM
VD7- REAR BUMPER-REINFORCEMENT-ALUMINUM
VK3- MOUNTING, LICENSE PLATE, FRONT
VT5- BUMPER-COLOR KEYED (W42)
V08- COOLING SYSTEM, HIGH CAPACITY
V1P-
V30- GUARDS-BUMPER, FRONT & REAR PAINTED (W42)
V73- STATEMENT OF VEHICLE CERT-U.S.
W42- CUTLASS 442
YT1- DOOR PANEL TRIM (W42)
YT9- FISHER ASSEMBLY DIVISION INSTALLED
Y64- ORNAMENTATION W42 PACKAGE *DECALS*
Y78- CUTLASS SALON OPTION
12L- SECONDARY COLOR, EXTERIOR, SILVER METALLIC
15U- PRIMARY COLOR, EXTERIOR, MED GRAY METALLIC
6NY- LEFT FRONT SPRING
7NY- RIGHT FRONT SPRING
79C- INTERIOR TRIM, CLARET
79I-
799- SEAT BELT COLOR, CLARET
8PZ- LEFT REAR SPRING
84Q-
9PZ- RIGHT REAR SPRING
