I would say that it really depends mostly on where the line is in relation to a heat source. Most fuel lines are metal for more than one reason. Reliability, durability, and safety. Rubber lines are necessary to allow for movement or ease of replacement, such as near a filter. Metal is almost always the better choice in most areas and applications, but can be more difficult to fabricate. Metal has a longer life span and doesnt swell or collapse the same way rubber lines do. Get the best rubber lines you can find, such as for fuel injection systems, which are 3 times the cost, but are 3 times better...JMOmobileaudio25 said:Does using a rubber fuel line promote vapor lock?
