I'm looking for ideas and possibly pics of how best to run my new fuel lines. I'm not pulling the body off so the pre-bent lines are out. Can't get them between the frame and body in several places. Also, that means I can't re-use a lot of the clamps to secure the lines the way the factory did.
I'm swapping to a TPI based 383. I have the f-body fuel rail which has the driver side fittings. So, I'll be running a 3/8" main line and a 5/16" return down the drivers side along with the 1/4" brake line going to the rear.
The passenger side has the 1/4" vapor line going back to the tank.
I've considered running the 3 fuel lines down the passenger side and then running the rear brake line down the drivers side by itself. I'd then run the main and return across the front engine crossmember to the drivers side.
I'm running steel brake line for my fuel lines and looking for the simplest and cleanest routing.
Any ideas?
Any ideas?
