S10 master cylinder swap
Sumariner
129
10
A guy on facebook did a swap with the master cylinder below. He said it was a direct swap. Anyone here used this master cylinder??? I plan to swap mine this weekend!!!
Did you Install this master yet? Did you realize any benifit to it? And why did you want to change the master anyways? are you running 4wdisk brakes? Im asking because I have the s10 fronts and rear ls1 I plan to install and I wonder If I should change anything else. If so I would like to have it before I start the swap. Thanks
I did install it. My old one needed to replaced. I prefer the screw cap design over the stock gbody design. The brakes feel very firm now. It çould be that my old one was just worn out.
It was a direct swap
Reactions: V8 Rumble
What year s-10 did you use?
After the install
I do like the look of this vs. The g body design...I also have the blazer brake upgrade and have noticed a big difference with them.. I'd like to know the results of this upgrade by another member that didn't need to replace the existing one though...After all, it's only $🙂
