S10 master cylinder swap
Bump on this topic. Just wondering if anybody else has swapped to this master with out having started with a bad one and noticed if there was any difference.
I have the s10 for the front plus ls1 rears. Dont know If I should do a master as a part of that swap?
Well I asked a question and got hit with a Disagree? Disagree about what? Was it a stupid question?
That 'disagree' is most likely just an accidental fat-finger on a cell phone.
I was hoping somebody with experience would chime in.
Your probably right. Im hoping somebody that has done this swap before and can give us a real comparison vs the factory one can give there 2cents on if its worth while to do.
Reactions: 383_GrandPrix
The heart of the matter is that a larger bore master cylinder will provide a pedal that takes slightly more effort but requires less travel for the same response. The S10 master cylinder wouldn't benefit me since my car was a diesel and I've decided to retain the hydroboost. The stock master cylinder for my car has a 1-1/16" bore. I looked up master cylinders for a 2000 S10 pickup and for a 2000 Blazer on Rock Auto and they show a 1" bore for those applications. If your stock master cylinder is a 7/8" bore then that S10 master cylinder would be an upgrade for you.
I have the SSBC front brake upgrade kit, and I'm looking at discs off of a firebird/camaro for the rear of my 86 grand prix. Would I be able to bolt this master cylinder and not have to worry about a metering block/proportioning valve?
If you go to rear disc you will need a disc/disc proportioning valve.
I have no idea what my master cylinder bore is. Oh well More research. Lol
If you look up the master cylinder for your car on RockAuto it will list the stock bore size.
