Does anyone have any part numbers for correct shift linkage for a Saginaw 4 speed in a 78 Monte. I have already fabbed up a mount to properly locate the shifter but would prefer to just but the linkage rather than build. Thanks all!
Thanks so much! This place is amazing for information. Can’t wait to be rowing gears!Rods:
10001119 Reverse.
10001120 First and Second.
10001121Third and Forth.
Lever Arms:
10001126 Reverse.
10001129 First/Second and Third/fourth.
I have a mint 4 spd shifter, rods and levers (that bolt onto trans) Came from a malibu, should be the same?Does anyone have any part numbers for correct shift linkage for a Saginaw 4 speed in a 78 Monte. I have already fabbed up a mount to properly locate the shifter but would prefer to just but the linkage rather than build. Thanks all!
All the 4 speed cars used the same shifter. Even some of the 3 speed shifter parts are the same (1/2 rod & arm is the same for R/1, 3/4 rod & arm is the same for 2/3, mount bracket.)I have a mint 4 spd shifter, rods and levers (that bolt onto trans) Came from a malibu, should be the same?
Are you looking to sell it? I’d be interested.I have a mint 4 spd shifter, rods and levers (that bolt onto trans) Came from a malibu, should be the same?
I would sell it for $300 USDAre you looking to sell it? I’d be interested.
Do you know what the shipping to 50070 would be.I would sell it for $300 USD
