Saginaw shifter linkage
Montecarlo78AMC
7
Does anyone have any part numbers for correct shift linkage for a Saginaw 4 speed in a 78 Monte. I have already fabbed up a mount to properly locate the shifter but would prefer to just but the linkage rather than build. Thanks all!
ELCAM
1,123
1,270
Rods:
10001119 Reverse.
10001120 First and Second.
10001121Third and Forth.
Lever Arms:
10001126 Reverse.
10001129 First/Second and Third/fourth.
Montecarlo78AMC
7
Rods:
10001119 Reverse.
Lever Arms:
10001126 Reverse.
Thanks so much! This place is amazing for information. Can’t wait to be rowing gears!
Clarmo
267
460
Ottawa, Canada
I have a mint 4 spd shifter, rods and levers (that bolt onto trans) Came from a malibu, should be the same?
9,167
15,345
All the 4 speed cars used the same shifter. Even some of the 3 speed shifter parts are the same (1/2 rod & arm is the same for R/1, 3/4 rod & arm is the same for 2/3, mount bracket.)
CopperNick
3,357
3,018
Canada
If this is not a period correct situation, then the shifter assembly out of an 82 Camaro will work. It also has the bonus of locating the hole/opening for the shifter on the top of the tunnel instead of at the side, meaning that if you are considering some kind of console it makes lining a lot easier.
