Thanks for the quick responses guys. As far as the setup, everything is coming out of my one buddies 3rd gen Camaro - Pedals, trans, bellhousing, master (for a blazer), and slave. I know the setup will work, it had no problem living behind his sbc 350, and in his brothers Camaro before that. I know his brother had it rebuilt a few years ago and made some upgrades. I'm getting the whole set-up for $400, which from what I've seen is pretty respectable. I'm also planing on doing the adjustable master mod that was done on ls1tech.com, but only on the rod that goes to the pedal. I figure it'll allow me to adjust the pedal, as well as not have to weld a piece to lengthen the rod.
I have thought about using the mechanical setup, but right now the simplicity and availibility of the hydro setup can't be beat for me. I had a hydro clutch in my 1990 Audi 100 quattro (damn I miss that car), and it never bothered me. Worse comes to worse I can always switch it around later.
Doug, thats just what I was wondering about, thanks for the advice. If it doesn't fit I'll just slap the stock pan back on for now I guess, I'm just trying to upgrade whats easier with the motor still out. Got a higher flow oil pump to go with the new pan, don't need anymore oiling problems
Another shot in the dark question
: What about the trans crossmember? I'm not buying a new one, my other buddy is a welder, so he can take care of it for me. I'm sure he can make it work without a problem, but I was hoping someone may have some pics and measurements of a T-5 crossmember that will work in my 84 Cutlass Supreme. Only reason is I'd rather be able to pull it and have him weld it up now so I can bolt everything in and go. The cars been off the road since before December and it's killing me to not be able to drive it lol, so now that I have the money together it's gunna be a mad thrash to have it done ASAP.
