sbc 350 Buick v6 transmission will it work
beanzELCO702
45
Just as the title said. Will the transmission from the. Buick v6 work on my 350. I'm not sure on the the v6 transmission is other than it come off the v 6. And it says. c6 on it. I know I could just get a 350 transmission. But. If the v6. Trans will work I want to put it on. Intill I find the Trans I want to go with.
if its the oraginal transmission and ur going to bolt a 350 buick up to it it will work but if its a chevy you will have to buy a aparter plate of jegs for $57
Check the bolt pattern not all buicks had The BOP pattern several had the chevy pattern aswell and the older ones had both BOP and chevy universal.
I think I. Have the universal bolt mounts. Can I use a 350 flywheel. With it also or do I have to use the one from the v6
i just done this like a week ago you use the 350 chevy flex plate... ihave the 200 metic transmission and my transmission is not wanting to shift right i have to find the problem
