SBO 350 Dipstick
joeairforce said:
Does anyone know if the SBO 350 uses the same dipstick as the SBO 307?
***Some do*** not all. Some early 307's used the same stick and tube, the later, used different ones than the 350. If you match stick to tube, they should swap out though.
You would have to compare them, the difference would most likely be in length (or bends in the tube), when in doubt buy the correct one for your application, they are still available new (but not for long).
Yup, they are still available from the dealer. They changed the stick however, it doesn't have the "loop" anymore, it has a bright yellow "T" handle :? .
Hmm..... may still have to go get one....... if anything I can get one and see if it matches my 307 one and then just use the 307 one...... and still have one to leave in the 307...... I'll check it out. Thanks
