I'm going to be rebuilding my motor almost completely since I was having oil issues before the driveshaft accident. So I figured since an Eagle stroker crank is so inexpensive that it would be a nice upgrade while I'm at it. My questions are:
-Can I use my 350 5.7 inch rods?
-Doesn't the choice of 5.7 or 6.0 rods effect the displacement? Which choice gives a true 383 ci motor?
-Are aftermarket crankshafts a drop in and bolt deal?
-If I keep the same flat top pistons, 882 heads, etc will the CR stay the same or is more chamber space utilized with the stroker motor?
-When did sbc's use 1 piece and 2 piece rear main seals?
I'd like to go with a forged crank just because of my paranoya of cast pieces in a performance motor. I doubt I will see anywhere near 500hp. I'm going to swap over the 882 heads that I was running on the 350 as they already have the larger valves, 3/8 screw in studs, HD springs, etc. Thanks guys.
