Get or borrow a flux core welder...almost fool proof. use the amp/voltage settings on the inside of the spool lid and set it on the lower range and test it out..then bump up the heat till you are confident that you are getting a good penetration. Mig/flux core welding is so much easier than arc/stick. Just remember that on thin metals, keep the metal cool by tacking it in small amounts til youve got it pretty covered. hover your hand over the metal and if its hot enough to make you want to move your hand, it need to cool. Dont rush it and you'll be fine. :wink:
