CUTLASS Seatbelt Sleeves?
Ahhhh! I found em now..they are with the actual receivers for sale it looks like..not just the sleeve. 👍👍
Yep! Message him, he might have the sleeves. Just not listed.
Otherwise i got a buddy in Canada i get all my parts from he's got a good sized shop he parts out g-bodies.
Reactions: RICKDIZZLE
I tried checking the sleeves in the Elk but had no luck- it's packed full of stuff, the belts are shoved under the seat, and it's a power unit with no battery in the car. I can't even open the passenger side. Sorry man, didn't mean to get your hopes up. Once the truck is out of the way I can open the driver's door all the way and remove stuff but that'll be a week.
No worries at all! Thanks for looking. I have the ones from Dixie coming so will try and make them work. Really just want something so the recievers don't fall down between the seats. I have my stock ones..but they are just cracked and tattered. I "may" try to use a heat gun to gently add a twist to em.
Reactions: Sweet_Johnny
I bought the inner sleeves for my Regal, when I switched to buckets I just needed one for the passenger side since I am using the belts from my 60/40 set up but these are just a hard plastic and are not long enough to hold the buckle upright so it just kind of flops over not real impressed.
I ended up just using the top half of the sleeve and gluing it to my bottom portion of my original belt sleeve after cutting out the twisted section.
I will eventually look for another driver's side to replace this.
