Shift lever
Ferret
Aug 31, 2012
82
6
Luxembourg
www.arl.lu
Hi everybody! I'm currently performing some important transformation-work on my Lemans and I need your help. I had to swap the original TH200C for a TH400 and I'd like to keep the original floor shift configuration. However, there is a shift equalizer lever, operationg some parts on the steering column. The original lever is not working, since it is too longand has not the correct angle anymore. Does somebody have a TH400 lever for my 78 Grand Lemans he could sell to me, or did anybody do similar customwork to get this kind of issue done? Any information would be helpfull 🙂
You can adjust the length of the rod by loosening the bolt at the bottom.
If you need to change the angle of the bend you can straighten/re-bend it in a vise as you see fit.
When I went from a 200-4R to a th-400, all I did was adjust the length...
Oops, I forgot tho precise that I didn't mean the lever-part that's going up to the steering column, but the other lever, fixed to the shifter-input on the transmission and the frame. Sorry fir my mess-up.
