Signal not kicking out
burgundy83
185
33
Saskatoon, Saskatchewan, Canada
My signal switch decided to stop kicking out only when I turn left, right still works as usual. I can still turn it on and off manually, and hold it halfway for lane changes. Wondering how hard it is to pull the wheel off and change out the switch, or if there's an easy fix to this.
It isn't the switch. There are two little springs on the switch that return the lever to center. The one for the left side is broken. They are cheap to get and easy to replace once you pull the steering wheel and the lockplate.
