username said:
I think Ive figured this out, it use's "slugs" which are like an eccentric bushing so you can change the geometery of the tierods.So now I have yet another question why dont more handling oriented folks use this to correct for bumpsteer? Maybe they dont fit under a stock frame or cost doesnt justify gains but I am curious now.I would be interested if anyone has any experience with using something like this.
You have to remember is the circle track cars are set up to turn left and are set to rotate around the particular corners of a track. The panhar bar and the drag link (aka center link) although at either ends of the car affect each other so when setting up the panhar bar the drag link also may have to be adjusted. You set up the drag link and then you adjust the bumpsteer. The bumpsteer is basically the last thing you do. If you change anything then you may have to redo the bumpsteer. You can't always use what is used in a circle track car on the street. You'd have to set you car up for the roads and curves you plan on traveling on a particular day and if you pick up a passenger then you'll have to set the car up again for that extra weight
here an example of what we have to consider when setting up a circle track cars....there is alot of work and calculations behind those things that just turn left...
variables:
A 32" drag link at 13 deg.
A 32" panhard bar at 19 deg.
or a 28" panhard at 13 deg.
Using a 13 deg drag link angle and a 16 deg track bar angle with the same length (32") just educated guessing based on a photo.
The suspension compressing 2" causes a .4103 shift to the passanger side of the axle (caused by the trackbar) while it only causes a .3334 shift of the drag link axle side end. This will need a 0.0769 correction in the pitman arm to remain going straight.
The suspension drooping 2" causes a .4779 shift to the driver side of the axle (caused by the trackbar) while it only causes a .4103 shift of the drag link axle side end. This will need a .0676 correction in the pitman arm to remain going straight.
Using both a 13 deg drag link and track bar angle, with the track bar being 4" shorter than the drag link.
The suspension compressing 2" causes a .2917 shift to the passanger side of the axle (caused by the trackbar) while it only causes a .3334 shift of the drag link axle side end. This will need a 0.0417 correction in the pitman arm to remain going straight.
The suspension drooping 2" causes a .3590 shift to the driver side of the axle (caused by the trackbar) while it only causes a .4103 shift of the drag link axle side end. This will need a .0513 correction in the pitman arm to remain going straight.
For ease of discussion this drawing assumes their origin is the same point, but this is not true and most likely never is. Therefore uneven compression or extension throws everything out the window.
Red arc = 28" length
Blue arc = 32" length
Green line = drag link at ride height
Purple line = unparrallel equal length panhard bar at ride height, drag link at 2" droop.
