Smog/air pump
Froggys86
230
56
California
I was wondering on the smog pump is the pulley supposed to move? I was given one and won't turn......so wondering if it's seized and if so can I unstick it?
69hurstolds
7,387
15,586
GM says: NEVER LUBE AN AIR PUMP or get liquids in it. If it's siezed, you should replace it. They may know something we don't. Probably because it will pump oil mist into the system and ruin cat converters and junk.
Yes. It should turn easily, but not spin like a pinwheel. It's obviously a pump, so you should feel it ever so slightly move the guts inside, but it's such a lightweight pump it doesn't take much.
Unfortunately, they're not supposed to be rebuildable by the common man, but I've never had one apart. If you muck with the plastic filter fan in front and try to remove it, you'll damage the seal. If you remove it, you'll likely damage it. And imagine that, the new filter fans are not available. So I can't tell you anything more than what you have is a siezed up A.I.R. pump. MAYBE you can get it to work? I have no idea.
With few exceptions, the 307s from 81-86 use GM p/n 7838575.
Saw an NOS one on ebay for nearly $300. Ouch.
The lowest priced pump (rebuilt) I could find was $155.
https://www.ebay.com/itm/3741128688...d=link&campid=5335822911&toolid=20001&mkevt=1
Cardone- 32-220 or NAPA- NAP 51220 (out of stock at NAPA)
They're getting harder to find. Partly due to lower demand, and mainly because people tend to throw away good cores. I'm starting to think my plan of keeping and using stock parts was now a pretty good idea.
Froggys86
230
56
California
I see figured that much but I do appreciate the response/knowledge
brrian
142
92
Pittsburgh, PA
See this post. Mine was seized. I fixed it, and it's been working ever since. Once I had it open enough to see what was inside, I was able to gradually loosen and clean it without WD40 or any other lubricant.
Edit: I remember that I didn't completely separate the back (painted black) from the front housing. It slid on a center rod, far enough that I was able to get inside to clean, but I didn't want to force it apart & risk damaging something.
  • Useful
john87442
198
203
Geneva ohio
I might have one for you. I’m switching my 87 442 over to a 350 olds and won’t be using the smog system. I’ll have to check it out when I get home in a couple days
abbey castro
896
1,111
Harker Hts TX
i took mine apart on my 81Vette and cleaned the insides, put it back together and works fine (no noise at all and it sucks! They are real easy to take apart, just don't go crazy mit das hammer or the screwen drivers to pry!
