GM has had ECMs since 78. A/G Bodies didn't get them at first, but not sure when it started. They didn't do much anyways. Con lockup, run the O2 sensor and CCC carbs.
85t5mcss said:GM has had ECMs since 78. A/G Bodies didn't get them at first, but not sure when it started. They didn't do much anyways. Con lockup, run the O2 sensor and CCC carbs.
85 Cutlass Brougham said:GM used a few different computer setups in the early years of computer controls. The earliest GM EFI was in 1975 and was on the Cosworth Vega( multiport EFI), and maybe on select Cadillacs, where the 500's got TBI in the mid or late 70's.
The earliest system used in G bodies was not the CCC system (Computer Control Command), but the C4 system ( Computer Controlled Catalytic Converter)in 1980. It does not have a TPS, but does have the MC solenoid. I looked at one a few weeks ago, and noticed this anomaly.
BTW, the first use of EFI on a passenger car was in either 1957 or 1958 on the Chrysler 392 Hemi. Fewer than 100 were made and were recalled shortly afterwards as the system was not potted, and the behind the grille mounting of the ECM got waterlogged and shorted out.
(Other firsts: ABS in 1972 by Mopar, GM had airbags optional in 1976, IIRC)
Sorry, didn't actually mean that 78s had CCC. I was just groupnh it all together. 78 TAs had an ECM (friends car still has it). I didn't realize that ABS and some of the other notables have been around that long. Good read for info on that stufff. So who has the answer on the first supercharger and what it was used on.joe_padavano said:. Do you know which 78s used the CCC?
85t5mcss said:[So who has the answer on the first supercharger and what it was used on.
85t5mcss said:Don't know, I just know they have been around longer than me and my parents. :shock:
