Soft brake pedal after swap
Bengler455
19
11
Recently purchased and installed a QP 9" rear for my 84 Cutlass. Upgraded to the Wilwood Pro Street disc set up. I have bled the brakes countless times and still have a soft pedal and brake light on. Do I need to upgrade my proportioning valve? Anyone else have this issue? Thanks
Built6spdMCSS
5,839
9,769
Florida Beach
Well, if you have Disc Brakes all around it would be wise to have the Disc/Disc Combination Valve, that is what it's called.
Then bleed it correctly, there is a procedure for them where you lock the safety piston in place.
Rocknrod
All Around Good Egg
98
88
This is a good explanation -
Supercharged111
4,956
7,758
Colorado Springs, CO
So they mention the valve would knock itself off center and then imply it's a nightmare to put back in place. Same would be true if you ran the front or rear channel dry on the car. What would then be the procedure to re-center the valve? I'm betting that's what happened to mine and the OP's since his brake light is on which is an indication of that valve being off center.
