Hey guys just wondering if any one out there is running solid motor mounts on there car and if so do you need to run a solid mount on the transmission. I have a 350 motor and trans in my car and i'm having trouble with the cross member it needs to be moved forward alot. I moved the motor back to the next hole and when i did that i put solid mounts on it got the trans closer but still way off any suggestions would be appreciated.
