Sound Deadening?
its called self adhesive foam pipe insulation. and just for the floor i used 4 big rolls and 4 small rolls. ill go to home depot tomorrow and take a pic of what im talking about.
vlad
Well, as an experiment, I bought the smallest amount of Fat Mat I could get and have a chance at doing the minimum that I had to do with it. Don't buy it. It IS just peel and stick roofing material with a logo-and it is much more expensive. It's very thin and smells like fresh tar and asphalt. I am guessing that is what it is. I will use it for now, but will probably go in and do the pipe insulation idea over top of it later on. I'm just glad I didn't buy the big kit and waste $130.
sorry guys had no time to go to home depot since i got a new job. none of the 2 links are the stuff. it is in the plumbing department and it is a 1" thick foam with foil on top and its self adhesive. also i tred finding it on their site with no luck.
EDIT: just took a drive to home depot and took some pics on the cell foam:
and here is a smaller one:
i used for the floor alone 4 rolls of the big one and 4 rolls of the small one
hope that helps;
vlad
this stuff looks awesome,
however, if i ever want to replace it in the future, can i peal it off easily and apply a new layer?
or is the adhesion really strong, and i'd have to cut and scrape it off? Any suggestions if this is the case?
you should be able to take it off pretty easy since the adhesive isn't very strong.It works good for the floor but i would recommend to put a some glue under it if your putting this on the roof. Also if you look at the 3rd pic second line from the bottom says it can be used as sound deadener.
vlad
awesome, I think I'll be using this once I get the floor fixed!
Thanks
