sparkplug reading is a great knowledge asset for tuning
here's a few things you need to know.
- things to read are the;
1. Base-circle of the plug: sutt or lots of black on the base circle means rich idle. This is not necessarily a bad thing, often big cam or aggressive engines require a slightly rich mixture to make up more performance higher in the rpms. Rich idle can be cured by adjusting your metering screws.
2. Porcelain center: the porcelain is a good indicator of heat and fuel mixture as well. You want to see a slightly brown/off-white color, no gunk. White color shows a lean fuel mixture, black or gunky shows rich or oil burning. If you see a white color, with small black dots, this is a dangerous scenario with too much heat, you are about to melt parts.
3. Ground strap: the strap is a key indicator in sparkplug reading. The strap indicates the heat "shedding" ability of the spark plug. On a clean burning mixture, look closely and you will see a color change halfway down the strap, ideally at the the bend before the base-circle. If the color is too far at the top of the strap, the combustion is too cold, try increasing timing. If the color is too far at the bottom near the base circle, the combustion is too hot, try retarding timing. You want the color change right at the bend, this indicates a perfect plug temperature range and timing mixture.
Basically, with the above information...
after you've played with your carb mixtures and timing, and your plug's base circle and porcelain show nice clean colors, but you are still seeing too much heat on the strap; it is time to move to a cooler heat range. Try one range at a time, make hard runs, adjust timing if necessary, and see if it's sufficient.
I have factory aluminum heads on my small block, running 10.7:1 compression. I was using factory spec NGK plugs (I believe V-Power part# FR4). After playing with carb mixtures and timing, I found I could not run the ideal timing without too much heat and knocking. I then moved to the next heat range (part# FR5) and tried those. I found my ideal mixture and performance with two heat ranges cooler (part# FR6); this combo showed the best performance at the track without excessive heat.
... that being said, with quick heat-shedding aluminum heads, I find better street performance from the regular #FR4 plug with the higher heat range.
