The more HP you have the less gap you should run. I
not according to this guy
"I have been dyno testing for over 40 years. The ONLY time I have ever seen plug gap make any difference is when you make it BIGGER.. I one instance, I got a 22 horsepower INCREASE by going to an 080 gap, from a 035 gap. I will admit, that is a real big difference, but I have had several guys tell me that the big gap was a big HP increase. I always run them at 055 to 060 in my serious race engines- The big gain was on a 990 HP big block, and the engine just would not make over the 1000 HP number.. When I did this, it was a really big deal, to make 1012 HP
JOE SHERMAN RACING"
That is a ton of HP with plug gap. Do you dyno with the same ignition system on everyone engine? There might be something not quite right there. The only thing that really changes is the timing of the spark when you change the gap. The spark doesn't do anything but light the fuel (at the proper timing)
We run .010" gap on my buddies 3000hp ProMod
