speaker question
rizo3506
24
I been seeing a lot of people doing 4 6x9 speakers in the decklid . How can i do that and what do i need
axisg
2,685
2,357
YYZ
notch the seatback so the speakers sit flat on the decklid
axisg
2,685
2,357
YYZ
if you take out the seatback you will see the metal support. The decklid is appx 5" wide. You will need to cut a notch abot 1.5" wide and 6" long in the metal seatback to allow your 6" speaker to mount flush. Otherwise you can use the plastic adaptors but I always found they would rattle and have the speaker hit the trunk support rod.
Crappy pic from the inside of the trunk. You can see I have bolts temp holding the rear of the speaker in place while I drilled the front. As well you can see the notch cut in the metal seatback.
