Hello
I've been struggling with a transmission leakage at the speedocable hookup at the transmission. This is a TH350 BOP trans. I've changed the speedocable, gear and gear housing. The O-ring on the outside of the gear housing was replaced as well.
I did not, however, change the seal inside the gear housing where the gear slots through. A replacement did not come in the package unfortunately.
In an ongoing effort to stop this infernal leaking, and narrowing it down, I have two questions:
1.) Does the speedocable itself (the screw-on part to the transmission) have ANY leak stop function, or should it (in theory) not leak no matter how loose/hard it's screwed on to the transmission?
2.) Is there supposed to be an on ring in the speedocable as well? Inside the part that is screwed onto the transmission?
Tommy
Tommy
