Will the speedometer and voltage guage from and olds cutlass bolt into a 83 Monte. Havent had to take one out before and dont know if they unbolt as seperate parts or is it all one piece. The reason I ask is the needle is broke on mine and the voltage meter dont work. Thanks for any help in Advanve. 🙂
if it's just the needle broken on your speedo you can replace the needle. It just pressure fitted onto splined shaft. When you remove the old one make sure you mark it's location so the speedo won't be off after installing the new one.
