FYI, GM used two piece cables just to burn off what was left of earlier cruise control cables. I have one out of a '86 Monte just like it with the union.
So any cable I buy today goes from the trans to the firewall? I just have to get the right length?FYI, GM used two piece cables just to burn off what was left of earlier cruise control cables. I have one out of a '86 Monte just like it with the union.
It actually WILL disconnect from the cable. You're just not using the right approach. It'll take more force to get it apart. It may not want to, but someone may have mucked it up beyond repair.So I now understand that the cable is connected to a "bullet", and the bullet holds the plastic gear.
The bullet will not disconnect from the cable..
If you can just tell me where I can find a single cable and the bullet, it would be much appreciated.
Mosdef gonna order all of these first thing in the morning.It actually WILL disconnect from the cable. You're just not using the right approach. It'll take more force to get it apart. It may not want to, but someone may have mucked it up beyond repair.
If you want to ensure you have enough cable, you can always get the Pioneer CA3003. It's 100" long and it doesn't have any sections in it. Guaranteed it'll reach with whatever transmission you have.
If you don't have a good idea what kind of transmission you have, I'm going to simply go with what you said, a TH350. Even if it's a 200 or 250, it's the same bullet.
Here's a bullet.
https://www.amazon.com/dp/B003TQ5LWE/?tag=gbody-20
Good luck.
