Ss gauges
Ribbedroof
4,973
7,209
Wellston, OK
Yes. You will need the entire pod assembly with printed circuit board. You will need to do some minor rewiring, directions can be found on the Malibu racing website. You will also need to change the oil pressure sending unit the water temperature sending unit and either add a resistor wire in the alternator circuit or wire it to useA warning light as well to work properly
Ribbedroof
4,973
7,209
Wellston, OK
The existing housing/pod will not accept the gauges and printed circuit board, This is why I say you will need the complete pod assembly
