Ss nose swap
Hopefully when they slapped the nose on that Monte they transferred everything required from a SS.
Also installing ground effects shouldn't involve anything more than adding a few extra holes if done right.
CAR had everything I needed
Clean the nose up a little also
I’m having a hard time install the head lights one side bolts up but the other side don’t have holes to where it bolts on fender etc
Do I make holes ? By the way
Does it look like I’m going in the right direction
Looks good, now you need some sport mirrors.
Reactions: dr78442
View attachment 74355 How do I install the fender extension?
There should be a couple of tabs on the front of the extension that slide into the nose and then a couple of screws hold it in place that are mounted in the wheel well.
  • Creative
Reactions: Onehit
Do I have to have the extension to be able to bolt it because I don’t see any holes to bolt it
I notice my fender curves a little is the normal or would a body shop have to fix it
It looks like your fender might possibly be bent in a little, you have to remove the chrome trim before you can install the extension and the nose should hang a little past the fender and that is where the extension tab goes in and then push the extension tight against the fender to drill the holes in the wheel well
Yeah both of my fenders like that
