This is about the only thing that is bothering me now. The starter is almost brand new from the looks of it. I had problems when I got the car so I messed with some shims. I got it almost perfect now but it the gear hangs up a bit after it's running and I get a high pitched noise.
I think the tip of the gear probably got a little bent from it hitting the flywheel. Should I try to file it down or just get a new starter? If I get a high torque mini starter, do I install without shims in the beginning or should I put back the 2 that's in there? I would hate to spend the money on a new starter and ruin it the same day.
By the way the engine is a 1975 Chevy 350.
